Come on John you really are stretching this beyond the limits here. You and Ebee seem to be plucking ideas out of thin air in an attempt to justify his rubbish maths.
I have not ever tried to 'justify his rubbish maths'. I have
explained what he did (since you said that you 'could not fathom out' how he'd done the calculation) but always with the qualifier that the validity of the mechanics of the calculation was dependent on the probabilities of failure of the two devices being independent.
Furthermore, for unknown reasons both of you are now stating that this calculation can also be justified by the fact that the environmental conditions will contribute toward similar RCD failures in the home. This has been dismissed by the report - please read it!!
I don't think you can have read (or understood) properly. If I understand you, I've been saying the opposite of what you suggest. I have been saying that the more commonality there is to the environmental conditions of the two devices, the
less valid/justified is a calculation of the type ebee undertook.
If we follow Ebee's approach to its logical conclusion that means despite already having all circuit RCD protection at the board you should also be putting a plug RCD in every socket used by every appliance is ludicrous you know it.
It obviously depends upon one's view of the risks involved. There's nothing conceptually wrong with suggesting that one might consider (which is all he said) a 'belt and braces' approach if one's primary protection is less than 100% guaranteed to protect. As I wrote, whether or not one decides to do that depends upon one's judgement of how great the risk is in the first place, how likely the primary protection is to fail, and what one's attitude to risk is. As you say, most of us have decided not to adopt that belt and braces (even though we have virtually no useful data on which to base that decision). You are perhaps someone who would happily jump out of a plane without a reserve 'chute, and would regard it as ludicrous to even consider having one - on the basis that you already had one level of protection.
As for attitudes to risk, if it were only fatal outcomes that concerned you, then you might as well forget about RCDs completely - since the probability of dying from electrocution in the UK (about 1 in 3 million per year) is roughly ten times less than the probability of your winning the Lottery if you buy one ticket every week (about 1 in 270,000 per year).
Furthermore, if one RCD goes the other will as well - absolute rubbish of the highest order.
That's only the 'ultimate' (obviously hypothetical) case of a very valid concept - that the more commonality there is between the nature, age and 'experiences' of two devices, the more likley it is that they will both have failed by a particular point in time - and hence the
less justification there would be for a calculation such as ebee undertook.
Kind Regards, John
