lights
Will 0.75m2 be ok for 2 lights on a 5 amp plug???
It probably will be OK - meaning that the flex should comfortably offer a current carrying capacity of 5 amps. Though if the lamps are 100 watts each or less then you could use a 1 or 2 amp fuse to protect the cable.
My answers assume that you are running a short length of flex not buried in a wall with insulation or something similar?
its four core cable, gonna use 2 wires per light
4 core flex would normally have one green/yellow insulated core, which can only be used as the earth connection.
How exactly were you intending to connect the cable to the lights and plug?
bulbs are a maximum of 40watt, yeh mains rated use to use em to wire boilers up?
Well you could protect with a 1 amp fuse in that case. I still say that is a long run of flex and sounds like something that should be wired properly as fixed wiring in 1mm or 1.5mm twin&earth or is it a temporary arrangement?
Good point. the flex will need a connected CPC even if the light fittings don't need it.
its for 2 lights in the shed just plug it inside 20 turn lights on when am in it of a night ive looked in to spuring off with a fuse spare and running a 2.5mm in to the shed, but the nearest socket is a radial not a ring and am not paying loads of cash to run it back to the consumer boared its other side of the house lol ( and before any1 starts was getting a spark to do the spare :rolleyes: lol )
It's OK to take a spur from a radial.
its got gray, black, blue, red in it ??? what the spark gave me from my old works sat in shed just wondered if it would do? plan was 2 lives (sleved brown) from the 4 core and 2 neutrals (sleeved blue) going in to wall mounted terminal box and some 3 core to a plug. the lights dont have any earth points on them all plastic ? how could i earth it when there no earth points ?
Why don't you just use an extension lead and a lamp or two to plug in to it, for those nights you need to be in the shed?
hummm .. thought you couldnt spur of a radial single twin and earth to the plug .. or am i thinking you cant spur of a spur?
