thought of that but be a pain in ass having reel it out just to nip in it for few mins an wind it back up, plus am sleving the wire in some 15mm plastic pipe before the decking gos down
hummm .. thought you couldnt spur of a radial single twin and earth to the plug .. or am i thinking you cant spur of a spur?
Just to avoid potential confusion, what you've written could be taken to mean that one can run a 'spur' from an existing unfused spur, provided that the 'second spur' is fed from the first by an FCU - but I don't think that's the case, is it?You can not spur from a spur unless you use an FCU or similar.
I presume what you meant is that one cannot run a second socket from a spur unless that 'first spur' is a fused one fed by an FCU from the main final circuit (in which case one can connect as many sockets as one wishes). Was that your intended meaning?
