I was speaking to a sparky this week and I am still not sure on tackling the situation that I have.
Coming from a 100A supply to an outbuilding is around 80m 16mm² with first half being T&E and the other half being SWA which goes to an outbuilding. The two are joined/connected via a CU. The T&E is mostly overhead cable because of restrictions preventing SWA underground.
Anyhow, I have built a large garage/shed and I am nearly ready to wire it but I am debating cable size. Equipment such as a powerwasher will be used so I doubt it will use anymore than 4000w.
Distance from the CU which connects the T&E/SWA, to the new building is no more than 150M due to route and I will most likely get 150m to be on the safe side. I had thought 25mm² would be ok but the sparky told me 16mm² would be better and most importantly he mentioned problems connecting 25mm² cable hence why he said to go with 16mm².
Not sure what to go for but I was thinking the distance and you never know what I might want to connect or use in the future. One thing I didn't ask was using a larger cable coming of a smaller cable i.e running 25mm² cable from 16mm² run. Is that allowed?
Cheers for any suggestions.
