See 525 and in particular 525.3
Am I right in thinking that without knowing Ib for every circuit, for an installation with single or multiple submains feeding the final sub circuits it's impossible to either measure or calculate in accordance with 612.14 (i) (ii)?
The circuit may not be under load conditions at the time so how could the voltage reading be relevant to volt-drop?
It would be interesting standing in a running shower, cover off (shower cap on - pink one) and £600 tester hooked up to the supply terminals![]()
Back to 525.1 - ....under normal service conditions....
I hope the NIC don't want to see a graph attached to the PIR showing maximum cable length v current for different conductor cross-sectional areas with different percentage volt drops for specific nominal voltages, conductor temperatures and wiring systems for every circuit![]()
