Hi there,
My company want to put up a blockwork structure to carry out some noise tests. It needs to be 5x5x4m (l,w,h) and of a fairly heavy construction for acoustic properties. We are currently thinking of single skin dense concrete (7n) blockwork with steel beams supporting a felt/bitumened stirling board roof with concrete paving slabs layed on top.
Been trying to get my head round Part A to see if there are any issues and have to admit i'm still in some confusion regarding the permitted building height and required wall thickness! Wonder if anybody could draw on any experience to advise if this proposal is acceptable.
1. Based on a calculation on the windspeed diagram and associated tables of factors, it seems 4m height is fine. But then there are other diagrams/tables stressing a 3m height blanket maximum. Is that just a worst case scenario? Presumably you can go higher than 3m, but then do the suggested wall thicknesses not apply etc etc? Dont have to start reading British Standard documents do I? Noooooo...
2. There seems to be different wall-thickness requirements for residential dwellings and single story non-residential buildings (which I assume this falls under), but it's generally quite unclear which requirements apply to which structures. The paragraph about single story non-residential buildings suggests 90mm - so a single course of blocks should be ok, probably requiring a central pier in each 5m long wall. Can anyone confirm if that's OK.
3. I calculated about 5 tonnes for the proposed roof giving a roof loading of 2KN/sq.m. This is what's suggested for floors in the Part A doc but greater than a roof (max 1.5KN/sq.m for a <6m span). Is this a factor that'll put up the required wall thickness?
Aaarggh it's a minefield for me, so if any experienced builders out there could offer any advice it would be appreciated. At least is this proposal there or thereabouts, or bonkers and liable to collapse around us? Also any idea what I should be paying a small building firm to put up this structure. Oooh I forgot to mention it's going on an existing thick concrete slab so no foundations required.
Lastly, should whomever we engage to do the work be checking the structure meets regs, or will a builder essentially build anything you tell them too (within reason) that may not meet regs? Or will this need planning permission, and the suitability, or not, of the proposed structure come out at that stage?
Any help appreciated. Cheers,
Liam
Liam
