We had the above installed last February, and it was working fine until May. Since then it's only been serving hot water, as it's been warm(ish).
Over the summer we've done some fairly major building works, which has involved removing/changing the upstairs radiators, and adding in 3 additional ones.
So, yesterday with it getting a bit cold again, I went round and slowly filled up/bled the radiators. No leeks (a result
....but...
When turning the system back on, it all fires up, goes up to 70c, and the rads warm up, infact they get hot. But after about 20 minutes, the boiler keeps on clicking off. You can see, it turns on the CH, you watch the guage go upto 71c, then it just turns off, back to the std pressure display (which is at 1.3bar if it's relevant). It then does this constantly.
I've been round and checked all the rads again, and while most are hot, some are not great. I've also noticed the Return pipe into the boiler is very hot, and also some of the rads only seem to be hot on one side.
I can't get hold of my plumber at the moment, so I'm looking for ideas, as I've reached the limit of my knowledge.
All rads have TRV's. The boiler has an external Room Stat, but I've removed it as a test, and the same thing happens.
HW is working fine.
Any clues would be great......
Thanks...
HW is working fine.
Thanks...
