if that was my garage i would dig off the oversite with a mini digger before any blockwork is laid.
what difference would that make?
i'm a fairly competent digger driver, so the cost of a digger against two men mauling for a day does not add up.
it would be fairly simple to dig off whilst there was no blockwork in the trench.
all this is speculation if you have no rear access.![]()
screed alone should not be used for a concrete slab.
a screed mix is not suitable for a floor slab.
you will need to lay a concrete slab, i.e. ballast (sand and gravel mixed), cement and water.
screed should only be used as a secondary layer.
As nose says.
1:3 fine, no need for additives, just don't go laying them in freezing conditions, cover with hessian at the end of the day.
