S
stedon1
Have just finshed my second class on my 17th edition course. The tutor has told us that if the cable is buried less than 50mm from the surface or is not protected by steel pipe it must be on an rcd. Fine. If the circuit is wired surface it does not need an rcd. Also fine. Does the surface wiring have to be protected by steel pipe or can it be pvc pipe or mini trunking?
