I'm currently planning the replacement of my consumer unit. Before anybody asks, I've been in touch with the LABC, and I am going to be submitting notice to them next week before doing the work, and testing it all thoroughly myself (I have a full set of test kit) regardless of what the LABC do etc etc...
The circuits I have/will have are (ratings are based on load and I have verified that existing cable sizes are appropriate based on installation method and length etc using the tables in the wiring regs, I'm replacing the one cable that isn't sufficient at the moment):
Circuits that will be direct from the main switch regardless, either as they don't want to be RCD protected, or have a high likelihood of tripping:
Supply to consumer unit in brick outbuilding (40A RCBO)
Shower (40A RCBO)
Supply to computer servers (16A MCB)
Smoke alarms (6A MCB)
Burglar alarm (6A MCB)
Switched maintained emergency light by consumer unit (6A MCB)
Circuits that will either be RCBOs, or MCBs fed from an RCD:
Electric oven/hob (40A)
Downstairs ring main (32A)
Upstairs ring main (32A)
Immersion heater (16A)
Downstairs lighting (6A)
Upstairs lighting (6A)
What I'm trying to decide is whether to use a dual RCD board and split the last group up, or just get RCBOs. The cost difference isn't huge (about £40 more for the RCBO approach), so that isn't really a factor.
The obvious positive of the all RCBO approach is that one circuit tripping will not take out any other, but I'm worried as to how tricky it will make getting the cabling neat inside the consumer unit with all the extra neutrals (I'm currently looking at getting a contactum metal clad unit if anybody has any experience with those?).
Does anybody have any thoughts on this, in particular can anybody think of any other pros/cons to either approach?
Shower (40A RCBO)
