Hello there.
I am looking at some ch problems I have been having (hot rads upstairs, med hot rads downstairs, one rad downstairs not working etc etc!)
Decided to draw up the pipe diagram so i can understand what does what.
The small water tank in the loft - there is a 15mm pipe @ btm which comes thru ceiling before upping to a 22mm then to pump in airing cupboard. There is another 22mm pipe which tees into it before the pump (From Boiler?).
Anyway there is a valve in the 15mm section which was turned off ie no water can enter system from header tank??
I am no expert but figured this should be ON not OFF. Am I right and if so would this have been causing my heating probs?
My boiler is a Glow Worm Space Saver 50-60. Has anyone got a manual for this?
Cheers
Steve.
Cheers
Steve.
