D
Deleted member 105431
ps,and as for the other parts replaced they was all diagnosed from this forum so not all bg,thanks.
so bg use a diy forum for fault diagnosis? It just gets better. . . .
To elaborate on what Tony has said.
You need a full service to the boiler, this involves removing and cleaning the burner.
Consider a BG technicians role, he/she visits sveral boilers in one day and each may be of a different manufacturer or model. He/she cant possibly know all these boilers so, he/she gets out the laptop and follows basic dianostics, now due to the time limits pushed upon him/her will restrict the depth they might go to diagnose faults.
By the way Im not BG Iam independent.
What you have is a dirty burner, once cleaned all will be well.
With all the parts thrown at it you have a nearly new boiler to boot.
we've had the boiler serviced since we moved in so july time - i was just thinking about time they are 'allowed' to spend at each job but i reckon it is the burners
BG don't "service" boilers anymore they do a "safety check"/emissions test. Bit like Kwick Fits free safety checks on cars-worthless. If you want a proper service call in someone else.
we had a corgi registered plumber in to service boiler - he also changed the gas supply pipe to the bolier because it was a 15mm pipe not a 22mm or whatever it is like it should of been - i'm thinking that mr bodgit and scarper installed it in first place incorrectly and not as it should of been ( we have no thermostat on wall ) resulting in us 4 years later buying house with dodgy boiler![]()
a sh*t cheap and nasty package.
maybe you could get a better job, earn more money and buy decent quality products. Heatlines are for peasants. Buy a better house too.
BG wasted several visits replacing parts which were not needed.
Any competent engineer would have checked the cross lighting strip, set the min/max and ignition and CH pressures and the boiler would have been fixed on a single visit.
I am sure that ZK, Mehran or I would have sorted it out easily on one visit without any spare parts!
Tony
Tony
i have no idea why dangermouse46 hates heatline so much...i mean it is part of the company he works for god sake.
i think telling some one that they should get a better job and house because the boiler they have is a bit below the belt and very rude.
dangermouse46 you work for valliant group which heatline is a part of now. slagging off a part of the very company you work for does not reflect very well on you.
and to the OP your boiler is a good boiler. i fit heatline boilers all the time and do service agent work for them. they are a great simple straight forward boiler which i would be happy to have in my house.
