Have patience. I think these are simple Qs and As. I'll provide as much info as I can.
I need to know how to install my new electric oven. The kitchen is fitted and is just waiting for the oven. There's an original cable down the wall to a switched cooker point (with socket). Then a cable runs down and along (behind tiles and cupboards) to where the oven will be. It's just a cable with no connection point at the end so far. The cable is twin & earth (not sure of the size right now but it's larger than lighting cable - braided/multiple copper strands for live and neutral).
I have a cooker point to go onto the wall behind the oven unit. It's just three cables to screw in, right? How hard can that be?! It's from there I get confused. It should just be some more cable screwed into the cooker point and into the oven, yeah? But having read the manual and some other threads on the forum I'm getting concerned that things have not been done correctly.
The manual: http://products.gorenje.si/fts/getDigitDoc.asp?sifra=663031&jezik=en&tipVsebine=1
The oven is a Gorenje BD8860E. The manual says it comes with a power cable (page 14, paragraph 3) but I haven't got one! It recommends a H05RN-f cable in the diagram (page 14) and it shows different schematics for different voltages and thicknesses of cable used.
Q: Where do I get this type of cable? I only need a metre or so.
Q: Where do I screw it in? (The diagram has five different terminal points.)
The technical data (page 19) shows the wattage for the ovens and grills. I am concerned that the original cable to the cooker switch, and new cable to the cooker point, are not big enough for the cooker. (Which would be a real pain as the kitchen is finished and the cables could not be easily replaced!)
Q: What size fuse and twin & earth should be there for this oven?
Q: Is twin and earth from the cooker switch to the cooker point the normal way to do it? In which case why do I need different cable to connect the oven (maybe I don't?)? After all, they're both behind the oven!
Phew! Thanks. I can provide photos if needed but I'm at work right now.
