wiring for built in oven
16 Apr 2006
Midlothian
hi folks i recently moved into a new house,i'm in the process of replacing the kitchen there is a gas cooker in it already but i am putting in integrated appliances ie oven,hob,hood i have taken the old gas cooker out and have wired for the hob ignitor and the hood not a problem but the oven is a problem in that there was only a 2.5mm cable feeding the cooker switch which was taken from an existing socket and no cooker outlet point,is it ok to run a 6mm cable from my consumer unit to the cooker switch then from the cooker switch to a cooker outlet point to feed the oven?if so what size of fuse do i run it from and does the fuse have to have ONLY the cooker switch coming from it? any help greatly appreciated ASAP lol
Do you mean you have a gas hob and an electric oven?
A typical UK single oven takes about 10 to 12 amps so will happily run off a 13amp plug.
hi john yeah it's a gas hob with an electric oven the oven is an oven and a half have just checked and its a double oven john
How many amps does the oven take when both bits are running?
Have a look in the user manual, it will have a specification in there saying the power of the oven(s) and grill(s).
might be described in kW or in Amps.
If you can't see the max amperage load specified, see what are the largest loads you can have on at the same time (e.g. in most ovens you can't have the grill and the oven on at the same time, but you can have the upper grill and the lower oven).
Somewhere in the installation instructions it ought to say what kind of supply you need. Was it delivered with a flex and plug?
hi have managed to dig out user manual and the wattage is 5.0-5.5kwwill i have to connect to the 30amp fuse in my cu
JohnD
Is that a typical DOUBLE or SINGLE oven.
I dont think the word typical can be used on an appliance such as an oven.
Edit
You had assumed he has a single oven
Diyisfun said:
JohnD
Edit
I specified that it was a typical single I was talking about.
