Hello,
Admittedly, this could be a dumb question
but just wanted to double check the following.
I have a Pulsacoil 2000 boiler which gets electricity through a fuse connection unit. It has three switches for: 1. pump, 2. off-peak heating, 3.on-peak heating. Check here for picture: http://www.diynot.com/network/jo75/albums/2072/7798
Recently, the off-peak switch broke down but I could still use the boiler by using the on-peak switch. But during the cold spell the boiler broke down altogether (i.e. I could not get any hot water anymore, boiler would not at all heat up).
Before checking whether there's an issue with the boiler, I'd like to check the electricy supply. Would it be safe for me to take out the fuse near the switch and replace it with a new one? I have a feeling it may have been belown. Is it enough to just keep the switch switched off and then open the fusebox, or should I switch off electricity altogether?
Any advice much appreciated!
Thanks so much,
Jo
Thanks so much,
Jo
