Hi guys,
I realise this isn't particularly DIY related, but I haven't a clue where to find another forum as busy as this populated by qualified electricians, so I hope you don't mind me picking your brains.
I work in IT, and for the last 9 years (across two jobs) we have generally accepted that PAT testing fries computers. Despite our electricians always insisting that the tests are safe, we always experience a good number of failures, and no matter who we ask, we've never been able to find out why this happens. My understanding is that electronic equipment is only subjected to an earth leakage test, which should only affect the power supply. However we've seen blown power supplies, motherboards, processors and hard drives in the past. We've even seen a blown fuse in a mains lead after a PAT test.
We've always wanted to understand what's going on, mainly so we can try to reduce the number of failures we get, and this year I finally have a theory. I've no real experience with electrics however so I'd like to ask you electricians if this sounds reasonable:
1. The first key assumption is that we're going to assume that the kit is already faulty, and is going to fail the earth leakage test. This implies at least one faulty component within the power supply, although it's not bad enough to affect the operation of the computer.
I think this is the key to the problem since we can't think of any way a PAT test would affect a properly working computer, and previously we've always assumed the PAT test was breaking computers, and could not come up with any explanations.
2. Next, am I right in thinking that during the PAT test, the faulty component is going to be stressed much more than usual? Instead of just potentially leaking to earth via that component (which is unlikely to happen), we have deliberately created a circuit using the short, and are running power through it. Am I right in thinking this could cause the faulty component (and indeed other components within the power supply) to fail?
If so, I think this could explain why computers that have been running fine for ages fail after a PAT test. The test itself doesn't cause the fault, but it can highlight existing problems, and actually make them much worse.
I think this is then compounded by the faulty equipment being turned back on (either by the users, or by ourselves not understanding the fault when trying to repair the machine - we're not always told it's a PAT test failure...).
And I think it's this final step that has most likely caused the computer failures over the years - attempting to use a power supply that is potentially quite badly faulty could cause all kinds of problems within the computers.
Our plan to correct this is:
- When any equipment fails the PAT test, as well as placing a notice on the users keyboard, maintenance will physically remove the power lead.
- When repairing failed equipment, IT will replace the power supply without making any attempt to power on the computer.
- IT will then get the computer PAT tested, and only when it passes they will power on the machine to ensure it is working normally.
Do you guys think this sounds reasonable?
