What wastage do I allow and one other dumb question!
28 Jun 2006
London
Hello experts.
I am fitting an engineered floor in the next month or so.
What % wastage would I allow on my calculation of 34.21m Square please? 4 Rooms which are all square bar one with a bay.
Also I am going for engineered floor which comes in packs of a standard length. As I would like a 'random look' I have been told that I can cut the planks to various lengths as I like. Is the end normally T&G'd? If I loose that T&G with cutting the plank is there a small chance of the two ends not being flat? I will be using 3mm of foam on 6mm ply on top of good floorboards. Ill also be using a good mitre saw to ensure square cuts!
Your advice very welcome thanks.
Standard is to add 5 - 7 % waste. For 4 rooms I would go for 7% waste (you're never sure you can use off-cuts from one room for the other).
You shouldn't cut boards shorter which go in the middle of a row - you'll loose the connection -, you can cut 'starter' boards (first in a new row) shorter to create a random staggered pattern.
Sorry! Madam. :-)
May have changed our mind now and going for solid.. :roll:
Engineered just looked abit too...well ... engineered.
Back to the drawing board.
Solid or wood-engineered? ;-)
Hi Woodulike.
Serves me right for going to B&Q! The 15% offer was too much temptation.. :oops:
But, I am taking your advice and finding a local specialist.
The engineered woods they did didnt look great and the solid pack lengths sempt very short to me.
Q. If I go for solid what is the max length I might expect in a pack if I am paying £50 per sq. m?
With us you would get between 800 - 2200mm lengths, where the shorter ones are maximum 10% of the whole lot.
