32 x 28mm coupler/reducer ? is there such a thing ?
22 Jul 2007
Cornwall
I need to connect an existing 28mm copper waste pipe to a 32mm plastic waste pipe or 'S' trap on a wash-hand basin.
Is there such a thing ?
many thanks
Is there such a thing as a 28mm copper waste pipe. I think not . :wink:
Thanks guys,
I am replacing a wash basin. It already has 28mm copper outlet pipe that goes down to - & into - the concrete floor.
It did have a brass trap, which was purpose made as an adaptor from a 32mm (or I guess it was 1¼” in those days) waste to 28mm copper (1⅛").
At some popint, I may replace it all, but at the moment I need to connect the 28mm copper to 32mm plastic.
I was hoping that there were push-fit couplers of 28mm that would slip onto the copper & a reducer from 32 to 28mm to take me to the trap size - but that would be far to simple !
Is there anything on the market to do this please ?
F
As I say "it isn't an option at the moment", but thanks for trying.
F
No, you are trying. I`m telling you how it should be done by a professional plumber. :wink:
Thanks for asking. :roll:
I'll re ask the question for other readers.
Is there a fitting that will allow me to connect a 28mm copper pipe to 32mm plastic pipe ?
cheers
cheers
Ask all you like, I can`t see any reason for you to connect to a copper waste pipe, which is normally too small to take a hand basin, are you stupid :?:
Bambergaspipe:
Why waste your time writing banal retorts when it's obvious that you can't help me ?
I don't care whether you can see a reason or not. That's not the issue.
I've asked for help/advice and you've given your version - for which I thank you.
As to my own intellect, I won't bore you or other readers with my academic qualities and achievements - but will add that it dosn’t give me the right to make crass remarks about other people – of any standing.
Hugh Jakeak:
Cheers mate. That’s looking something like. A couple of things to look into,,,,,
Thanks all.
Got it sorted thanks.
I got a 28mm compression to male threaded adapter and a 32mm plastic Female threaded adapter/insert that screws straight on to it.
thanks for reading.
F
(PS: thanks for the positive PM's re comments here.)
