I am planning to add a solar Heating system to my house.
I have a Gas Boiler. I would like to add a insulated water Drum where I would then have two coils in. One for the Solar loop and one for the Hot water tank intake. The Idea is to use the Water Drum as a heat storage during the day and if hot water is needed during the night or especially during the Morning it will preheat the water going in to the water heater.
Questions:
1. What are pro's and cons of a water heat storage?
2. what size would I need?
3. what size Coils should I use? (copper pipe ½;5/8? Single or triple parallel?)
4. Are there any plans for this kind of a heat exchanger
5. My thought was to use a big Plastic Drum, insulate it, do all of the Fittings thru the top, have one over flow to a drain that will double as overflow increase of a leak and as a Vent for moisture vapours.
Thanks for any comments
Questions:
