W
Water Systems
So yet again its an exploding cylinder that hasn't exploded!
That is a part of the unit. And one exploded lifting a roof in Newbury.
It did explode it seems.
Shall we discuss this in the combustion chamber, Big Burner?![]()
Just spotted the rust bubbles on the EV showing it had failed long before it split, its a wonder they hadn't spotted the rusty coloured hot water. lack of maintenance poor install same guy who left the filling loop attached? or is that because another fault is being cured with a regular fix.
Don't see many cylinder mounted EV's these days with good reason.
Being an RGI does not make you an Engineer and does not qualify you to pontificate on anything but gas.
The expansion vessel gave way, it did not explode.
There is clue in the photo http://tinyurl.com/cchhma
It is a solar cylinder made by http://www.hotwatercylinders.co.uk/ I have mentioned them before on here.
Nicely installed isn't it.
