I have just has a loft conversion done. The new shower room was fitted with a thermostatic shower. The plumber fitted a negative head 2.2 bar Salamander pump downstairs next to the hot water tank.
I am experiencing a few problems :
1. The shower pressure is not very high
2. The shower is not hot, the Grohe shower says that it is limited to 41 degrees but the water seems cooler than that
3. Sometimes when turing on the basin hot tap it runs for a little while then becomes a trickle. All the time I can hear the pump running downstairs
Any help would be greatly appreciated. The plumber is saying that it is not his problem and that he has installed the pump and shower correctly. Is the pump faulty or is there another issue?
Thanks in advance.
Thanks in advance.
