Looking at getting the garden done for next year so now in the process of planning and designing. So far im looking at a new patio area about 5m x 3m onto the back of the house. To the rear of the patio (paving slabs) im thinking about a raised bed on either side of either sleepers or some sort of softwood timber. The beds will be long enough to leave a gap in the centre of about a metre. This will form the access to the main garden area. If this is the case then the surface water is obviously going to run down the fall into the side of the raised beds, so im thinking of a linear drainage system to run along the full length of the patio or in two parts for each part to run alongside the raised beds only and leave the centre part free to avoid the kids walking and possibly damaging it.
Im thinking of different ways to doing this properly but also dont want to create unneccessary work. I can work out to lay the linear drainage but then what?
1. Is it best to connect this to an existing outside gulley. If so how?
2. Could i leave some sort of trench after digging out the earth to be filled with hardcore and geotextile for the surface water to drain into the ground. And finish off with decorative aggregate to bring the trench upto slab level so any water will drain through the aggragate and hardcore before it hits the sleepers. (Read this somewhere and not sure its possible or will work). Also sounds like making more work too.
3. Would it be even silly of me to think of a slight fall towards the house. There are to gulleys to the back of the house and would be much more simple to lay the linear drains here going straight into the gulley without any additional pipework etc etc.
Ideally i would like the first option to do the job properly but just after a few alternatives if possible.
