1) Boiler make / model (gas or oil)
Baxi Solo 3 40 PF gas boiler heating/hot water
2) What is / is not happening.
Has been making an odd noise for a while very noisy sounds like really hot water being sent through the pipes in bedroom (sort of a boiling noise very odd) the boiler itself making odd noises cant describe it running just sounds very loud. Today it has stopped running. On front panel, overheat led is not lit, boiler on and fan on led's are lit, pilot on and burner on led's are not lit. Assume the pilot has gone out but why and how do i relight it. I have followed reset instructions already and this did not do anything - everything came back on the same.
3) Has ANYTHING else been done or changed recently.
Primary circuit board replaced about Nov last year as packed up then. Landlord gas check done about 6-8 weeks ago and noise that sounds like really hot water being sent through the pipes in bedroom started after that check i thought nothing of it tho.
5) When does it happen? eg, heating coming on or going off.
This problem with not working occured this afternoon at 4.30pm ish
6) Anything else you feel may be of relevance.
Please any advice you can give I am on my own with 2 small children, rented house and landlord reckons cant get anyone out til mon (i will be working so i guess tue then!) and my boiler supplies my heating and hot water i also have no back up immersion hot water tank and i have no family they are 250 miles away thanks appreciate any help. I have no intention of fiddling with anything other than the panel just wondered if there is a way to reset it also it seems to be wired into electrics directly cannot find an electric turn off switch is this usual.
