Hi there, yes I know it's yet another fan question, sorry - I have searched before on this but I'm still confused.
So, had place partly rewired by electrician, we have problems with fans in 2 bathrooms. Ideally I wanted the fans to come on with the lights and then when the lights go off run on their timers then switch themselves off.
One of the fans seems to come on when it wants, sometimes when the loft lights are turned on, then it will run sometimes for ages without cutting out. The other fan (which the electrician installed) sort of worked ok but when isolated somehow it would dimly illuminate the low voltage downlights in the bathroom.
The one the electrician has done from start to finish (forget what they're called - bit in middle opens like a camera lens) he's wired now from it's own switch so you have to turn it on outside the room if you want it on, the other one still does what it wants.
The circuit they're on has lowvoltage downlights in some rooms, tungstens and fluorescents in the loft.
Please help, I can put up with the one he's done although its not ideal but the other one drives me mad.
Cheers.
Cheers.
