Hi All
I'm about to embark on a selfbuild conservatory and have a couple of questions relating to the dwarf wall and DPC's
Dwarf wall spec is as follows; 450 x 225 footing, 1 course of trench blocks, 2 courses of brick work (2 skins with 50mm cavity) This brings me up to exisiting house DPC level. 600mm wall on top of this.
I have 2 options for the vertical joints adjoining the house, either 'tooth' the dwarf wall in, in which case could I avoid using a vertical cavitray by opening up the cavity in the house wall and continue it into the dwarf wall ?
Or use a vertical cavitray and tie the dwarf wall to the house wall. Not sure which is the best option
I have a similar dilema concerning the opening for the french doors into the garden. Is it better to use a vertical cavicloser between the 2 skins or return the brickwork and use a vertical DPC ?
All help, suggestions welcome
Robin
Robin
