Helping a friend move in to a new place and we found that the downstairs lights are not working. I checked the consumer unit and the MCB had tripped, I tried resetting it but as I switched it back up there was no mechanical resistance and it just flopped back to the off position. I then noticed that the MCB was loose (lower screw connecting to the bus bar was loose - tightened it up but still no good) I then decided to remove the MCB but someone has butchered the upper screw terminal and I can't unscrew it to disconnect the conductor.
As it was getting late I chopped the conductor off just above the MCB and wired it in to the MCB for the upstairs lights as a temporary fix ( both lighting circuits running off one 10A MCB)
Any suggestions as to how to shift the screw on the faulty MCB? or is it just a matter of brute force? The MCB is a Gewiss B10, are these easily available or will any other fit the CCU.
TIA for any help
TIA for any help
