Can two system of combi boilers be linked to give a greater heat output to the central heating??, or would can you link two heat only boilers and use external pumps?
The reason I ask is that I need to heat a space which needs 20kw of heat in its own right and is 12meters away from the boiler at its furthest point, and am thinking of pipe heat loss ect,total building requirement is 40kw including other areas.
Any advice greatly appreciated.
Thanks.
Thanks.
