Hi guys
I've had some experience with building stud walls but always from floor to ceiling. I want to put up a stud wall that doesn't go to the ceiling, the resulting space will be used for wardrobes space.
The wall will be fixed to an existing masonry wall and the span will be fixed to masonry at one end and another stud on the other. Their won't be much load bearing, mainly need the strength at the top for the wardrobe telescopic arms to be fixed to.
How do I go about fixing the frame? Build the frame and then fix to the floor and wall? Fix sole plate first and first stud to the wall and last to plate, fix head plate and then fit studs between?
