I currently have a gravity hot water system and pumped central heating fed from a conventional boiler. The galvanised water tank is in the airing cupboard above the hot water cylinder. The tank is quite old and might begin to leak. I’ve got a new plastic tank from my neighbour. I plan to use it to replace the old tank but move it into the loft. The CH top up tank is in the loft and I will replace this at the same time (this is also galvanised). I’m retired so this job will cost me less than £50 in materials.
Unfortunately whilst checking the cylinder I found the heater coil joints corroded so this will need to be sorted in the near future. I’m now talking £250 plus for a new cylinder and a slightly more difficult job to tackle myself.
The whole system currently works fine but do you think it’s time to fork out £2000 plus to replace it with a combi?
Mike
Mike
