My front pads are wearing a bit thin especially on the driver's side front wheel where there's a slight grinding sound coming from it when braking.
I've not took the wheels off for a proper inspection but I know the pads definitely need replacing. I was told that they would need replacing soon by the mechanic that serviced my brakes around December time last year.
Today, I had a quick look at the driver side front wheel and I think there's about 3mm left on the outside pad. I touched the brake disc and the surface was quite uneven. Like it was grainy or something. Then I thought well will the discs need replacing as well? I don't think it would be good for new pads to be getting rubbed against a bad surface. What does anyone else think?
I've owned the car since 14k miles and it's almost done 49k now. I've had it for 4 years. I don't think the discs have ever been replaced as I've never replaced them and I don't think they would have been replaced before when I bought it.
I think I should drop the wheels off and inspect properly. Is there anything else I should look out for to see whether the discs need replacing?
Any advice is much appreciated.
Thanks,
Jay
Thanks,
Jay
