Connector blocks, with a difference
17 Apr 2009
Hello
I'm looking for the connector blocks, aka connector strips, aka choc blocks, that have a strip of metal under the screw to clamp the conductor.
The advantage is that conductor(s) can't slip up beside the screw. I know that the plate has a greater surface area than a screw, with the same clamping force, and I know that this means the friction is less and the pull-out force is smaller, but I still like them.
Does anyone know of a supplier of these?
Thanks.
What current rating?
From CPC
  • 1.5mm² 17.5A(6A) CN07080
  • 2.5mm² 24A(10A) CN07081
  • 4mm² 32A(16A) CN07082
    Ratings in brackets are the old British Standards ratings
I don't need any for 4mm² - only 2.5mm² and below.
Is "CN07080" meant to be a part number? I still can't find the item on the RS site. :(
Crimps certainly give a mechanically stronger connection, but they can't be quickly disconnected and re-made.
