Scenario :
(i)spur from inside the house, straight back through the cavity to outside
(ii)into outside conduit, which then carries the cable further along the wall to an outside socket
So, where the cable comes out of the wall into the conduit connection fitting, there is room for the elements to get down between the crack an onto the cable.
How do you avoid this scenario? Do you put a sealant around the fitting/wall or do you use a coupler/adaptor which sits snugly between the wall and the fitting.
I've probably not made this very clear as to which bit I mean!
