A friend has a home made "softener" made using the magnets taken from an old computor floppy drive .
You have two transistors in ther
If it still works, it generates a square wave which then feeds your coil through a 680 ohm resistor:
Does it still oscillate? If the frequency is within audible range, you could try putting a speaker in place of the external coil
Voices.And what should I expect to hear from a pair of speakers
Well I shall be listening out for youVoices.And what should I expect to hear from a pair of speakers
Wonderful, special voices.
They aren't easy to hear, but if you concentrate long enough you'll hear magical voices carrying the secrets of the Universe.
AquaHydroChem said:Are those the 2 black thinks marked up with NC and the diagram that looks like a diode
So putting your multi meters through it would not tell you if it worked or not
Stoday said:I suggest a pair of EL84s driven in push-pull mode instead of the transistors.
AquaHydroChem";p="1238329 said:
Could the green 272s be the Transformerless; they have 3 terminals on and one of each go to the big think in the middle coved up with solder bit small for a 555/556 though
But that's only 17 watts! Stick some EL34s in there with an 800 volt HT line and you can have a hundred watts.You might even shake up a few bicarbonate ions with it.
90 watts; wear are you going to get 800 volts from
A typical multimeter does not put out enough voltage when measuring resistance to push any current through a semiconductor junction. That's what the Diode Test function is for.![]()
No it was giving a DC current
Do the instructions tell you to use a plastic pipe?
Or is the a.c. from the oscillator rectified (and smoothed with that 4.7μF capacitor)?
Instructions Mickey Mouse
Dose not say but on the pix it’s a copper pipe
These things use an ac current from an oscillator to create a varying magnetic field around a copper pipe. That copper pipe is an electrical conductor. Lenzes law says that if a varying magnetic field is applied to a conductor, that conductor will have an electric current generated in it that produces a magnetic field that OPPOSES the one that originally generated it. ( or something like that!)
This means that the varying magnetic field cannot penetrate the copper pipe. This is why cables carrying delicate signal currents are screened using a metal sheath or even....an earthed copper pipe.
Throw the thing away and look at getting a proper water softener.
So your saying that the copper pipe conductor wont amplify the signal
Stoday - we have one of two things going on here.
Either the whole thing is a wind-up, in which case no answer he gives you will be of any use.
Or when presented with technology more advanced than a bucket and sponge he is so completely clueless that no answer he gives you will be of any use.
I think he has provided enough secrets for now to keep you baffled for the entire existence of the universe
I'm out of here - it's not enough of a challenge to even take the p**s out of this pathetic liar any more - good luck to the rest of you.Could the green 272s be the Transformerless;
