We have bought an electric double oven and seperate ceramic hob to replace the the old seperate oven and hot plate hob.
The new oven needs 5.2kw and the hob needs 6.3kw, which I understand means 22amps and 27 amps respectively without taking diversity into account.
I have an existing 30amp socket (used by the old cooker), which I can connect one of the new items to (probably the hob as its juicier).
However I am now a bit stuck on what to connect the oven to? I have been told by an electrician friend that I can run a supply off one of the existing power sockets to feed the oven - however I'm not certain that this is the right advice. I know that in theory my total supply requirement is 49amps - but I fail to see how that can be split between two connections and two appliances (that is how he explained it).
Any help/advice gratefully received.
thanks
thanks
