I have a couple of external corners to skim around - they're both 45 degrees.
I've done the plasterboard and thought I'd be able to open up a thin skim bead, but it's too stiff to bend, so I thought I cut off one "wing", then it went into a spiral and kinked when I tried to straighten it, so that's in the bin.
Then I thought I'd use some micromesh, which I more successfully tried to open out, but it loses it's straightness and I'm sure it would look naff if I try to skim it.
So now I think I'll stick some scrim on the corner, fix a batten to one side, skim up to it, and when it's gone off a bit, remove the batten and do the other side.
Is this the right way to go?
