Is this a better product?
http://www.screwfix.com/prods/63138...Volex-2-Way-RCD-Garage-Consumer-Unit#[/QUOTE]
A little, but not by much. You should be looking at MEM, Wylex, Merlin Gerin, MK and others.
So will splitting into two 16A limited circuits not be safer and more useful than the one 32A of the Rubber Box mentioned earlier? (Which also has no weatherproof 13A sockets)
It would certainly make it easier to bring it down into 13A sockets. If you had a 32a - 2x 16A distro with fused outlets then you could (
probably) then have
internally fused 13A extension strips wired to 16A commando plugs without the need for ridiculously large conductors that you wouldn't be able to terminate into the extension strip.
Honestly, please explain how a £250 unit with no weatherproofing is more durable in this "second harshest environment" you describe than the one I envisage making?
Perhaps because it's made out of rubber?
Also, I expect the particular unit you're looking at isn't designed for outdoor use, but rubberbox will manufacture to spec, so I'm sure they could make you something with weatherproof 13A outlets.
