Whats wrong in this pic?
14 Jun 2006
Surrey
Quite a few little jems on the CJ website :lol:
346x319.aspx
why use a drillbit when you can just swap the live pin for a neutral one and wire straight into it? :shock:
i am a plumber so have not been electrically trained but as it is turned off i would only class that as AR (at risk) not even ID (immediately dangerous) although it is RIDDOR reportable :lol:
RIDDOR has some one been hurt :cry:
No it's a metal bit and they are drilling into wood ply behind. Just left it there while getting the cordless out :)
Ah, I see it now... the right hand socket is not the right shape to fit the backbox.. the IP rating is comprimised because the corners are open....
I don't think anyone has to be hurt for it to be reportable under the Reporting of Incidents, Diseases and Dangerous Occurance Regulations :wink: .
IIRC this photo is a wind up from some radio operators in the gulf - it has done the rounds a few times!
Look guys, apply common sense,
This is a simple home made single pole Knife Switch where the wooden handle has has yet to be fitted.
I thought you made the report on the fourth day of person being injured. if absent from work.
Unless something nasty has happened :(
Yeh your right part F.
S**t I've got loads of them to do :!:
Ridiculous. That drill bit is far too big. It is clearly bending the prongs on the fuse holder. Amateurs :roll:
The drill is too long preventing the replacement of the top.
A .22 caliber bullet would be a better choice. :idea:
