Could do with some advice on this one if you guys can help. I'm trying to add a few extra sockets into the smallest bedroom which is soon to become my workshop. Currently there's only one single outlet near the door and I wanted to add two dual gang sockets on another wall. I checked behind the existing single socket and found a cable coming in, and a cable coming out so assumed this socket was on a ring and was simply going to extend it. However, I've just removed the socket, separated the two lives and found that only one of them is live with respect to the two neutrals. If this was indeed a ring, shouldn't they both be live? Also, behind the socket you can see a dual gang socket in the next room which has three cables running to it.
Any ideas on what might be going on? We only moved in about 8 months ago and I know that whoever wired it was a right numpty, as I found a metal light fitting on the wall with the live connected in a bit of taped up choccy block and the earth wire cut off completely!
