First post on DIYnot and I've had a quick look around but couldn't find an answer...
I'm planning on getting an RGI to move my boiler approx 50cm from the corner (outside wall) of the kitchen so that I can install secondary glazing and internal insulation.
What I need to know is, does my boiler (Saunier Duval Thema F23E, about 10 yo condenser) flue need to be moved as well (by law / regs) to keep it in a straight line (i.e. shortest distance) or can some pipe-work trickery be done to avoid getting a chippie to move bricks about etc. The 30cm flue brickwork opening / neighbour rule won't be a problem...
I ask as my flat is three floors up so need to know if I've have to get some scaffold and a chippie in...
I'll probably be getting scaffold up, just planning everything...
Any advice gratefully received.
Cheers,
Tony
Cheers,
Tony
