cut the nozzle at an angle to the desired bead width & pull the gun at the same angle, don’t push it; the trick is to apply the bead in one fast, continuous action using moderate pressure on the trigger. With practice you will get a nice even bead every time. The mistake practically everyone makes is to apply the bead too slowly; a natural thing to do but it usually has the opposite to the desired effect. All you have to do to finish it off is spit on your finger & run it along the bead; or if you don’t like the taste of silicone, use a drop of watered down Fairy Liquid as Woody suggests.
You wanna run me through that again?You should have a small 2mm gap to allow for expansion. I silicone in 2 stages; leave the nozzle uncut & inject between the bottom of the tile & tray & scrape off any excess flush, cut the nozzle to the appropriate size & run a second bead between the face of tile & the top of the tray, smooth off & job done; none of my showers leak.![]()
How do you seal "between tile and tray" if you left "no gap"?No gap you just increase risk of leaks by leaving gap, you seal the tray to the wall , tile down to tray and seal again between tile and tray giving a double seal against the water.
Which bitYou wanna run me through that again?You should have a small 2mm gap to allow for expansion. I silicone in 2 stages; leave the nozzle uncut & inject between the bottom of the tile & tray & scrape off any excess flush, cut the nozzle to the appropriate size & run a second bead between the face of tile & the top of the tray, smooth off & job done; none of my showers leak.![]()
If the tray drops 1-2mm then there's something wrong with the floor.
