Does that really need to be considered?
What about the spur in the airing cupboard for the immersion heater? Surely there's more risk of a burst pipe in there? But are waterproof connections used?
Colin C
Quite a maverick!
First (in another thread), you suggest baulking at moving downlighters that are ill-positioned, now you suggest that environmental factors need not be considered when selecting and erecting equipment.
an airing cupboard doesn't regularly have water freely running in the open above it..
ccam:
Perhaps I should have put a smiley on my post. It was a light-hearted dig...
Mine does...Is it not supposed to be like that?
Are you dabbling with plumbing issues again. Thought you'd have taken the hintan airing cupboard doesn't regularly have water freely running in the open above it..
are you often messing in there splasing water about? or running to answer the door or phone when you've left the tap on filling the ( bowl ) tank? and do you not have a ballvalve on it? or conversely a ball valve on the kitchen taps so that they trun off once the bowl is 2/4 full?
I'm not trying to be awkward ( it comes naturally, I don't need to try), I'm just trying to point out that with human intervention there is a higher chance of water getting into the socket under the sink than of an immersion overflowing or bursting..
If you'd made electricity safe when you boys invented it, then we'd not have a problem.far from it, trying to keep our lovely electricity away from the dodgy plumbers water..
