I think it all depends on whether there is a drain in the floor or not.
The ones in your picture/examples are not showers.But whats the difference between the ones in my examples, and the one in the OP's picture?
From what I can see, the only way to use that 'shower' without causing some sort of flood, which would require mopping up, would be to direct the water flow into the basin.
Also the drain hole is not on the picture, sorry about that.
Yes it can. Even if it were to make a mess on the floor it is a shower.So, IMO, even though the bit that squirts water is sold as a shower, when installed it this situation, it can't be used by someone to take a shower,
and therefore it is no more a shower than the flexible pot washer in my picture above is.
So if you were installing electrics in a room where they had got as far as installing the supply pipework, and had put an instant shower on the wall for you to connect up, but hadn't yet put the bath in, would you do your work as if the room was not a special location?I think it all depends on whether there is a drain in the floor or not.
The suggestion was for a Code 1, requires urgent attention.It's hard to see how you can code this as an immediate danger, when it's standard practice in the rest of Europe.
Preening yourself prior to a visit to Big Sister were you?Dry your bum while you're at it.![]()
On holiday in Prague, in the hotel, they had a hair dryer which quite easily reached into the shower....
Don't they have spirit levels in Germany?
