I've got a house that's had a second shower fitted in the ensuite.
The problem is that the supply comes from the box under the stairs and then up to the main bathroom shower and then along to the second one.
Both showers are 9.5kw and I'm not sure that the current configuaration will handle the load of both shower running at the same time?
Is this correct?
Is there a way to only let one of the showers opperate at once? Or is the only way to sort to run a second cable to the fuse box?
Thanks guys.
Is this correct?
Thanks guys.
