Garage Consumer Unit
11 Jun 2006
Cheshire
Does a consumer unit in a garage have to be a "Garage" consumer unit and IP rated or can a normal house unit do. The Garage units that I have seen do not have many mcb spaces.
:roll:
They need to be suitable for the environment they are installed in. Unless your garage leaks like a sieve, any standard CU will do.
However, the items sold as 'garage' consumer units usually have space for 2 circuits since it's only a garage - typically a light and a few sockets.
What are you intending to install in yours?
Them garage consumer units are awful - too small. And no room for expansion, so if anyone in future wants to add another circuit or anything, they are snookered. :roll:
There is a consumer unit in there already, it is near the door and has never been a problem but we are adding a shower, a cooker more sockets an attached summer room etc. so the unit needs upgrading.
Oh I see, this consumer unit actually supplies your HOUSE? Then its not a garage CU you need, but a House one! :roll:
No no-the house has one and this is a little extra addition that is separate from the house.
is the garage detached? are you making some kind of additional living space? have you informed building control?
Garage is detached and it is not living space. A Part P electrician is doing the work.
But it soon will be if I interpret this right . . .
My reference to building control was not with reference to electrics, but with your apparent intention to create aditional living space (which a domestic kitchen and "summer room" falls under). I believe additional drainage points and bathrooms must also be notified.
I'm not trying to wind you up, merely pointing out that you must inform LABC when carrying out work such as this on your home.
Well dont worry about anything Barnman the Part P electrician will take care of everything for you...He will know the answer to ALL your questions.
