My last thread was locked after it descended into a bit of a bun-fight. At the risk of kicking off again I wanted to put up a conclusion in case anyone comes across it in a search. Here's my original question:
Well, I fitted the timer, and my gas usage has plummeted. Furthermore, I haven't actually noticed any loss of utility; the boiler now fires up the heat store for an hour twice a day and I have as much hot water as I can use.
Additionally:
I fitted extra insulation to the various pipes exiting the boiler. They had some fitted from the initial installation but sloppily. This has helped a lot with the heat emanating from the hall cupboard. Now my socks don't dry as quickly
The Boilermate did not enjoy having it's power turned off at all. When I powered it on again, the relays on the two control boards started buzzing. Luckily the search feature on here came up with the solution - replacing the very cheap capacitors on the boards.
So, great success all around, thanks to everyone who contributed!
Ben.
As per title, I have a Boilermate in my flat which works well and provides oodles of hot water 24 hours a day.
However, I'm a sad single bloke, I don't use all that much hot water (I shower, honestly) and my gas bills are huge. The manual for the boilermate states a number of times that it is "most efficient" not allowing the heat store to cool down.
So, 2 questions,:
1. The boilermate seems to be internally insulated, but still gives off a fair amount of heat. Is it worthwhile putting an external jacket on it?
2. The manual also shows me how I can wire in a timer to shut the hot water function off (e.g. overnight or while I'm at work), making it a lot more like a conventional system. Again, this comes with a warning about efficiency. Has anyone tried this, or is there any hard information about what "more efficient" actually means?
I'm probably going to add the timer then watch my gas usage at the meter over a couple of weeks, just hoping to get some other people's experiences.
B.
Additionally:
Ben.
