Radiators all cold
Doubt supergirl, probably just knows there are 2 tanks in her loft....
When you get home, go into the loft and as Kev said, check the small tank has water in it and the ballcock works correctly.
How did you check the pump? Did you just feel or listen for it? This can be a false errand.... are you hearing any banging noises? Is the thermostat on the boiler turned right up?
ok thanks I will.
A guy came to look at the pump and said it is working and is the right one for the system and thought it needed a new valve and quoted me £300.
The thermostat on the boiler is upto max
Was thinking seems very high!!!!
Bung the system.... an hour seems reasonable
How exactly did he deduce the 3 port needs changing?
Bung cold feed and vent pipe
You could also shut a pump valve...
Bunged and changed 3 ports hundreds of times with no problem
