Radiators all cold
Bung cold feed and vent pipe
You could also shut a pump valve
I knew the bung bit, done it many times when removing rads complete with valves or installing TRVs and LS valves. Hadn't thought about shutting a pump valve.
Hi again,
right i've checked the tank in the loft and the ballcock is working ok...
The boiler is a stelrad ideal mexico slimline rs55
Thanks !
Lisa
Im charging 3 ports (Honeywells) at £135. I bung all with gate valves on the pump.
Price hike now!
Id whip the pump 'head' off and check the impellor is still attached to the 'shaft'.
Paul
Wish I did so I could charge £300 to do a 3 port valve!!
And I thought the owners of my silly little blue van with a flame on the bonnet were expensive :lol:
