Hi, I have recently moved to a flat and have encountered problems with firing up the boiler a Isa Ideal HE30. Can anyone help please?
1. I have used the fillling loop to set the pressure at 1.
2. The yellow gas lever is vertical with the pipe, can someone advise if this is the correct position, there is a sticker on it with left arrow as on and right arrow as off, however the vertical position is the most it can turn left.
3. The fault code on the boiler after trying to fire it up, (letter on led says d, and burner light comes on), after this led changes to alternating Ls and 9s. From the manual it appears to be overheating.
Not really sure what to do now, can anyone help please?
