Hi. My bungalow has just had an extension added. The builder reckoned that a Trevi Boost shower would be best (a mixer that uses the 'Venturi' principle). Unfortunately, the shower is not hot enough. I now have two different plumbers offering two different solutions:-
1) fit a normal mixer shower and replace the vented hot cylinder with a pressurised cylinder.
2) fit a normal mixer shower and add a pump.
Plumber 1 says the pump would be problematic - something to do with being too near the vent pipe/sucking in air.
The new hot pipe has been taken from the top of the hot water cylinder up into the loft, along 7 metres then down to the new shower. (It was not possible to put the new pipes under the floorboards.) The cold tank is in the loft, about a foot off the joists and right above the hot cylinder.
Does anyone have any views as to which solution is best?
Thanks in advance.
Thanks in advance.
