Just signed up, as there seem to be some knowledge on the subject. Now, I'm not a tradesman or the like, but fairly comptenet DIYer.
Oven - 3400W, 1.5-2.5mm cable, can be 13A plug'd if need be
Hob - 6000W, 4-6mm cable, 45A
I replaced the Oven about 1 yr ago but hob has sat in box (many reasons why hob not fitted at same time) but now its going to be fitted.
Behind the oven are 2x 13A switches (not sockets), in vertical placement one directly above the other. One wired to the Cooker Switch above the counter (big Red switch with light), the other into god-knows where but cabling is fairly chunky.
The Oven is wired to the lower switch which is connected to the Cooker Switch. The 'sparker' from the GAS hob (now removed - by Corgi Reg Gas Fitter!) was wired direct to the upper switch and not controled via the Cooker Switch - presumably so you could use gas hob without need for Oven to be on.
From reading the above I understand I can treat these 2 appliances as one.
How best should I re-wire this?
I'd get a spark in to do the job if it required a substantial re-wire but I seems like I just need to replace the 2 switches with a dual-purpose job and wire both to the Cooker Switch.
Can someone give me a few specific pointers?
